@Kyle - It might be worth mentioning to Hikvision technical (though they must surely be aware of it by now as it has been present for 6 months or more across various models of NVR and DVR). To reproduce - just pause playback and roll the mouse wheel back and forth. It should reverse frame by frame when going back-over. On some models it goes forwards whichever direction you roll the wheel. Tested with both supplied mouse and wireless (just in case there was a difference). If you were trying to get the clearest frame in a sequence to capture a number plate or persons face in footage, it's a pain.
Among others I've found this bug on:
- DS-7604NI-K1/4P (C revision K9B2 platform) - Firmware 4.72.106_220725. Haven't tested any newer versions of firmware (it was current at the time)
- DS-7616NI-K2/16P (original version) - Firmware 4.32.115_211129. Haven't tested any newer versions of firmware (it was current at the time). Will be able to check this model again tomorrow as I've just updated one to latest version.
- DS-7608NXI-K2/8P (K20A9 platform) - Firmware 4.74.000_230217. I set this NVR up today and loaded the latest version direct from the product page
