Analog camera integration into IP?
Muzo
Hello everyone,
I have 15 analog cameras on location A and 30 IP cameras connected on an NVR (Acusense) in location B with a distance of 30 meters apart.
All these are Hikvision brand.
I want to integrate the analog Cameras on the NVR.
My plan is to install the bridge for data transmission from router to DVR to have the same IP range with that of the NVR.
Secondly try to import the DVR IP address and add the active cameras.
Can that possibly work?
You can always add DVR to NVR and select which channels will be added to NVR.
