Adding Multi-Cam Units to IVMS-4200
Kraquin
Hello
I have a Hik DS-2CD6D54FWD-IZHS. I had it plugged into a switch and could see all 4 cameras of the unit through IVMS. Today I received my Hik NVR DS-7608NI-I2 and hooked up that same camera unit to it but could only see one of the four cameras. I then hooked up the NVR into the switch and added the NVR to IVMS. I read the tutorial on adding cameras to IVMS via NVR but I just get the NVR folder in the left sidebar of the Main View, no + to open it and configure cameras so no video. I did go into Device Management page then Camera Management for the NVR and modified the IP addresses of 4 of the 8 camera channels to match the IP address of the unit and assigned 4 individual channels to that IP address for each camera but no change.
Any suggestions much appreciated
thanks
Solved the problem. I was using the cameras original IP address instead of the one assigned to it by the NVR.
