32 Channel Acusense NVR
Marco Hill
Hello,
Can anyone tell me what is best/most recent 32 Channel Acusense NVR on the market?
Does a "full" Acusense NVR exist also, I noticed most of them are limited on their perimeter protection etc.
Thanks in advance
Hello,
Thanks in advance
Highest performance without going into the 64/128 channel beasts would probably be a iDS-7732NXI-M4/16P/X. That has 16 PoE ports or you can get the same model without PoE (but with dual LAN ports allowing you to segregate the cameras from the LAN using your own switches)
I'm not aware of any NVR that can process AcuSense by NVR for all channels. They're restricted by the number of channels they can process and the resolution of the cameras on those channels - that info is in the data sheets.
