A little background - we set up a 16 camera DS-7616NI-I2 a little while ago (from Use-ip).
After some issues with i-catcher and a seeming lack of development, a snap decision was made to replace this application with an NVR and a DS7604NI-E1 was available (from my home until a replacement arrives from Use-IP) to add to a different business, sharing the same web connection.
The 7604 has been working perfectly on hik-connect for over a year, so I can't see that being an issue, the system is known good.
However, once we have added it to this new network, it only stays up or broadcasts video to the mobile phone application for a few seconds before showing as offline on https://www.hik-connect.com/devices/page
I've changed the ports on the device to try and avoid conflict (HTTP, Server Port and RSTP port), and these settings are reflected on hik-connect.
The existing NVR (7616) has remained solid throughout.
Is there anything else which can be recommended to get 2 NVRs to play nicely on the same internet connection, or should they just work?
Thanks,
Harv
Thanks,
Harv
