Does anyone know of a wireless battery camera that supports an RTSP feed. All the ones I can find seem to be locked down to only using the supplied app / software.
Ideally it would be able to send an email on detecting motion as well.
I understand that Arlo uses RTSP for it's live stream. What is the exact RTSP path that I must use to get a valid live stream and are there any optional switches?
community.arlo.com
My gut feeling is that only the "professional" CCTV camera brands will support RTSP streaming (I know Hikvision, Dahua, Axis, Hanwha, Bosch, and Vivotek all support it) - the problem is, unfortunately, that these brands don't tend to offer battery-powered cameras.
The closest thing I can recommend are these Hikvision Wi-Fi cameras, but they will require either POE or a separate 12VDC power supply:
The DS-2CD2443G0-IW is now End of Life! Please feel free to look through our Hikvision category for a suitable alternative. Key features: - 4MP Resolution - H.265+ Compression Technology - 120dB WDR (Wide Dynamic Range) Technology - Provides Real-time Security, via Built-in 2-way Audio -...
Key Features: - 1/3" Progressive Scan CMOS Sensor - 2688 x 1520 Max Resolution - Powered By POE or 12v DC - H.265/H.265+ Video Compression - Audio & Alarm Interface - Supports Wi-Fi Connection - IP67 Water and Dust Resistant Rating - IK08 Impact Resistant Rating - IR Range up to 30m - 120 dB...
Key features: - 4MP (2560x1440) Image Resolution - Supports Wi-Fi connection for easy installation - 4x Optical Zoom, 16x Digital Zoom - Pan and Tilt capabilities | Pan range - 0° ~ 355° | Tilt range - 0° ~ 90° - 2.8mm ~ 12mm Vari-focal Lens, with support for Auto, Semi-Auto, and Manual Focus -...
