Web site integration
Hi John,
Here are a few url options to grab a stream from your Milesight cameras:
http://admin:ms1234@192.168.5.190:80/ipcam/mjpeg.cgi (Main stream)
http://admin:ms1234@192.168.5.190:80/ipcam/mjpegcif.cgi (Need to set sub stream into MJPEG)(Sub stream)
http://admin:ms1234@192.168.5.190:80/ipcam/mjpegthird.cgi (Need to set third stream into MJPEG)(Third stream)
rtsp://admin:ms1234@192.168.5.190:554/main
rtsp://admin:ms1234@192.168.5.190:554/sub
admin is the default user name
ms1234 is the default password
192.168.5.190:80 is the IP address of the camera used in these examples
Port :80 being the default port for web
Port :554 for RTSP in the last two examples
Obviously you'll need to update your own urls with any settings you have used or changed
Is there a MJPEG stream available from the Milesight NVRs themselves, or just an RTSP stream?
Josh
