WBox software on PC
cameraman123
Sorry if this is the wrong place to post this.
I have installed a WBox branded DVR (non-IP) with some cameras and its all hooked up to my phone nicely. I installed the CD that came in the box on my Windows PC however I can only see playback video about a minute delayed not live video, its connected via Ethernet (tp link).
Its the standard WBox Client software, does anyone know how to switch on live video? The cameras are just black.
Also I tried backing up some playback video and it saves to my PC in 360p resolution. Just wondering if its possible to connect to the DVR directly and pull down the files?
I also tried installing the web client instead through chrome and IE by going to the local IP (192.168.0.19), it installs but the browser thinks its not enabled as it required NPAPI to be enabled, which most modern browsers don't support anymore. Has anyone had this issue?
Finally if I turn on motion sensing on the DVR, will it send alerts to the WboX Vms1 app?
WBox is often referred to as a private label of Hikvision. It's possible that iVMS-4200 will manage the cameras from your PC. I don't have much experience with WBox but I do know they don't update their software as often as Hikvision. The software that comes on the CD is most likely outdated. Have you tried: Download for a up-to-date client?
