Video Motion Detection was invented back in the day when hard drives were tiny, as a means of getting multiple cameras to provide recorded coverage for a reasonable number of days on small/expensive hard drives (HDDs).
We don't recommend it.
It is still so far from a perfect art.
You will spend a lot of time trying to perfect the settings.
You will never achieve perfection.
You are likely to receive notifications about things that you are not interested in, and not receive notifications about things that you really wanted to know about!
You may find it quite challenging to configure the setup to detect and send you emails.
We always recommend continuous recording for security applications.
You can then be sure that you will miss nothing.
Hard drives are no longer small nor expensive.
Even 'edge recording' to a memory card inside the camera now typically gives you up to 64GB of space on a micro-SD card.
If you absolutely must use VMD then please buy an Axis IP camera.
They are the simplest to configure VMD with.
Their latest models have the most accurate detection.
