Replacement NVR for Hikvision DS-7608NI-I2-8P?
Pdcuk
Hi I am looking for a replacement for the Hikvision NVR DS-7608NI-I2-8P which has no fans or is near zero noise. Based on it being in an office location on desk.
I am using the Hikvision DS-2CD2385G1-I Cameras so would like to keep these if possible to work with new NVR which does not need to be Hikvision.
Hi @Pdcuk
How many cameras do you have connected to the DS-7608NI-I2/8P NVR?
Hi Dan thanks for replying I have 6. I just want a unit that does not have any noisy fans going all day based on where the NVR will be. Ideally something using a heat sink or near silent fans.
Thanks @Pdcuk
Unfortunately, most of the NVR models we are aware of that are fanless and will support 8MP cameras are only 4ch models.
The problem with making larger NVR fanless is that with more cameras connected and often multiple HDDs, these larger models generate much more heat.
Other users might be able to suggest their workarounds & fanless solutions for larger systems.
