K KamirZG Gives a lot of help Trusted Member Messages 255 Points 28 Jun 24, 2020 #1 Hi guys, does anybody have some experience on how to record audio files ( lets say from telephone, incoming/outcoming calls ) to hik DVR/NVR? Is it possible? Thank you
Phil Administrator Staff member Messages 5,189 Points 113 Jun 24, 2020 #2 If the NVR has an audio input, then you should be able to do that. Check the manual for your NVR for details on config etc.
K KamirZG Gives a lot of help Trusted Member Messages 255 Points 28 Jun 29, 2020 Thread starter #3 Just got answer from HIK tehnical support. Only way to record sound from Third party device is to connect that same device to camera's audio input. And important thing is to make sure that device support audio encoding : G711A/U: 8K G722 :16K G726 :8K AAC :8K\16K\32K
