I'm new to security cameras, especially IP cams and the current technology. Initially, i'd like to simply setup an outdoor IP camera to monitor the entrance area of my house without using a NVR system. If the initial setup works out well, I may go to the NVR configuration with multiple cameras at a later time. Of course, I want remote phone or pc access to the camera. I'm looking at the low end bullet type camera Hikvision DS-2CD2012 that Hikvision doesn't list as a Poe type camera. My Cradlepoint router doesn't support Poe so it wouldn't be an issue. Does Hikvision use a web based client server for remote access ? If so, I'm guessing that client video streaming over the internet to server occurs only during a remote connection period. ( I've discovered that some phone connection apps require a constant video feed to their supported web server) . If what's been pre-mentioned is feasible, are their any setup issues that I need to be aware of, and access to setup guides or procedures that might be available ? I just don't want to order this camera, discover that it can't be used in the environment I've described, and then think - damn, why didn't I thoroughly check this situation out
before buying. Sin
before buying. Sin
