Pole mounting cameras and cable entry?
a82j1
When installing cameras on a poles, what’s best practice for cable entry into the post?
Using cable glands looks to be quite common but it doesn’t easily fit neatly behind the Hikvision bracket.
I guess an easy option would be just to drill a hole?
Yes, just drill a hole, but if possible use a grommet or similar to line the drilled hole and prevent cable damage.
