Hi all
I recently invested in 6 Hikvison POE 4mp ColorVu camera setup and DS-7608NXI-I2/8P/S NVR for my home, and I’m after some advice please before I install it.
1. Is it ok to locate the NVR in the loft or not? I have the option to drop cables into top of an upstairs cupboard and mount the NVR there instead but it requires a little extra labour time. Easiest option is to put NVR in the loft but I’m worried about temperature - as all lofts, mine gets roasting in the summer and ice cold in the winter. I’m lucky enough to have full Ethernet in the loft so either options work connectivity-wise just want to know what’s best for NVR performance, longevity etc.
2. I’ve seen the hikvision mounting bases (DS-1280ZJ-DM22). Even though I’m mounting the cameras under the soffits, will the mounting bases add any value, i.e. reduce nighttime glare from the soffits and improve viewing angle, or would you recommend mounting cameras directly to soffits?
3. Would you recommend Cat 5e or Cat6 cable between NVR and cameras?
4. As all cabling will be in the loft space and the cameras soffit mounted, there’s very little chance of cables getting wet etc - do I need external grade Ethernet cable between NVR and cameras, or will regular internal grade Cat 5e or Cat6 cable suffice?
Thank you
Thank you
