Noise Problem
SciroccoPT
Hello,
I recently installed CCTV Hikvision HDTVI 1080p in one house and noticed some image noise and horizontal lines across a few areas on the screen. Does anybody know what is causing it?
I also installed another one on another house and there is no problem whatsoever. It's the exact same equipament. It has an amazing clear image without any noise or horizontal lines.
A few videos of the problem:
Thank you all!
It could be a voltage difference issue. If you are using a monitor what kind are you using, VGA or bnc?
