New I series NVR firmware is available on the UK portal V4.50.000 spotted by @dazulrich As he has mentioned in another post there are no release notes as yet. I've just loaded it and the differences from what I can see are:
EDIT 06-03-21: After another play this morning I've redacted a line from my comments above. My biggest annoyance with the V4 firmware was that (unlike the V3 firmware) selecting Smart Playback without then defining a line, intrusion area etc to search would tend to just display an unusable solid red timeline. To view events you'd set up in the menu the custom search was necessary which was a pain to use. With this update selecting Smart Playback will now show event markers for all configured events (ones that you have set up in advance within the Event Menu) whether they be Alarm Input, Line Crossing, Motion or Intrusion detection. This is exactly how I wanted it to work. Now I'd only need to use the Custom Search if I need to differentiate the event type that caused the trigger which I seldom do. Perfect!
- Flashing light and audible alarm schedule available for supported cameras? I'm not sure whether this is new or not - previously it was only available directly in the camera menu but I never bothered updating to the last minor revision (4.40.017) so can't be sure.
- Local GUI - alterations to how you switch between full and multi screen with a right click pop up menu
- Local GUI - Playback Min/Max Channels replaced with 1, 4, 8, 9, 16 way selection
- Local GUI - Redesigned timeline. The timeline scale is now selected using a dropdown selection rather than the multiple radio button style. You now drag a marker rather than dragging the whole timeline to navigate it.
Annoyingly there is still an event icon in red but no markers for preconfigured events in the timeline - no change there. - Events - Smart Events have been moved to Smart Analysis in the menu on the local GUI where there are separate sections for Facial Recognition, Perimeter Protection (Line Crossing, Intrusion, Region Entrance/Exit) and Other Events
