need some advice regrding my camera install wireing.
im fitting 2 mounts on foam insulated rendered wall. my question is regarding unsightly wires. i wanted to make it look a bit more tidy as black cat5 wire does stand out from grey wall and just moves around in wind. i thought maybe use white conduit to hide wires starting from where the exit point of camera wire comes through wall down to cctv mount. also thought white conduit would maybe blend in and match the wall mounts making to make it look neater install.
however is too high its around 8m high for my ladders also the wall is a rendered 90mm Grey Polystyrene (EPS) so normal cable clips wont work to keep cat 5 secure to wall
ive thought about ladder hire. and got couple quotes just to fit conduit but quotes were silly.
just wanted some advice, what you guys maybe would do in my situation? maybe give me a better idea or some pointers regarding best way to deal with the wires etc and also to make it look like a neater installation.
ive marked left wall ( B ) so show where other mount and wire will be exiting. ive not fitted it yet.
thankyou
thankyou
