Just thought I'd give an update on the solution I came up with to ensure the cable entry point on the DS-1280ZJ-DM21 junction box was water tight.
Some figures first:
1. The cat6 unshielded cable I was using was a slim 6.2mm in diameter. I purposely chose a "thin" cat6 cable to make it easier to bend while running the cable from each camera back to the NVR. Also, I wanted to make it easier to fit the rj45 plugs (that's another story as I didn't really succeed on this).
2. Looking at the earlier photo I posted, the gland opening varied from 17mm when full opened and 8.5mm when full closed. The 8.5mm gland opening versus 6.2mm cable diameter wasn't therefore providing a watertight seal on the cable.
3. So, I needed a grommet that would have a hole of 6mm and an overall diameter between 8.5mm and 17mm, so it would fit inside the gland.
I found these:
I purchased a pack of 20 from
Amazon for £3.99.
I would have preferred for them to be thicker to make it easier to locate in the gland, but it wasn't too difficult to position them so that the rubber seal of the gland squeezed the grommet.
Because they are a flexible rubber, I was able to push the slightly wider 6.2mm cat6 cable through them and they also squeezed tight when the gland was screwed down.
They appear to have done the job nicely and closed up the gland around the cable, hopefully making it watertight.
I also used the watertight rj45 cable connections that came with the cameras and used electrical tape on the unused power cable connectors just in case any water does manage to get into the junction box!
