Since normal HD monitor only has a resolution of up to 1080P. (1920 X 1080)
Does it make sense installing a 5 MP HD Analog surveillance system if you’re not using a
4K monitor with it?
As I understand it the 5MP has a resolution of 5MP 2560x1920.
This is not the case.
The higher the resolution of the cameras that you use the more detail they are able to capture.
Will be recorded.
You will be able to reveal by zooming-in when you play back those recordings.
