Hi. I would like to ask about max distance for cameras on 1 NVR. Am I right saying NVRs with PoE are capable of working with cameras which are max of 100meters away? Then it can be extended with either settings for long distance which will then go up to 300 meters or with use of extenders?
And what about NVRs without PoE? Is there a restriction? If so then what is the max distance? Or is it based on the external PoE switch? And what is the limiting factor? If I go over 100 meters is it going to loose power for the camera to work or the actual signal- data transfer?
And let’s say I have got big local network stretched over huge land and I need to run long cables to the corners of the land so I can have my cameras in there. Can I just connect few PoE switches across my network and then somewhere in the middle of the field in my office have NVR connected to that network? The cables from NVR to each of the switches would be around 200 metres. Is this doable? What should I be aware of in regards to the max distance?
Thank you in advance for any help and have a good day!
