My NVR does not want to do time syncing to locally connected cameras (they are connected directly to its PoE ports).
I think I have tried every possible combination, but nothing really helps.
For example, when I start Remote Playback on iVMS and press Pause, it shows that NVR's time is 00:00:14, camera #1 time - 00:00:13, camera #2 - 00:00:12, camera #3 - 00:00:13 and camera #4 - 00:00:17. If I don't do camera time syncing manually, time difference becomes bigger and bigger.
My settings:
NVR (WebUI): Configuration -> System -> Camera Management: Select each camera and click Edit button -> "IP Camera Time Sync." option is enabled
NVR (WebUI): Configuration -> System -> System Settings -> Time Settings: NTP option is selected, NTP Local Connection Port is set to Default, Port status is shown as Available, DST is enabled
NVR (WebUI): Configuration -> System -> Maintenance -> Time Sync Diagnosis: Status is shown as Normal
NVR (console): Configuration -> Camera: Click Batch Configuration -> Each camera has "Auto Tim..." option checked
Camera (Virtual Host): Configuration -> System -> System Settings -> Time Settings: Manual Time Sync. option is selected; I have tried selecting NTP option, but that does not help
Camera (Virtual Host): Configuration -> System -> System Settings -> DST: Enable DST checkbox is ticked (otherwise I get time zone issues on my cameras)
So, I don't know what else to try. It was working fine before, since I have updated the firmware for my NVR and cameras it stopped working.
My devices:
1. DS-7604NXI-K1/4P with V4.82.007 build 240321
2. DS-2CD2047G2-LU (C) with V5.7.15 build 240411
3. DS-2CD2347G2H-LIU with V5.7.15 build 240411
4. DS-2CD2346G2-I with V5.7.15 build 240411
My settings:
My devices:
