B bm_99 Member Messages 17 Points 1 Feb 11, 2021 #1 Hi all, looking to upgrade a system with all lillin ip cams and nvr If upgrade the nvr to a hik would the old lillin cameras work? Thanks
Phil Administrator Staff member Messages 5,134 Points 113 Feb 12, 2021 #2 Probably. If the Li-Lin cameras are ONVIF compliant, then you will be able to add them to a Hikvision NVR
