For 6+ years I've been running a DS-7716-I4-16P (purchased from Use-IP July 2017!!) with no problems and all 16 ports in use. Cameras range from earlier 2CD2155's to later 2CD2387G2's. All working as they should. In addition to this NVR I've also been running 3 wi-fi cameras (ieGeek 5mp, 12v supply) which I've been able to monitor on a PC via a HiP2P Client app. It's clunky, but usually works. Wi-fi signal is good.
A recent additional NVR purchase means that I've got 3 unused ports. What I've been trying to do for about a week is find some way of connecting the 3 (Onvif compliant) wi-fi cameras to my 7716 NVR. I've read and followed numerous 'how to' posts but still can't work out if it's actually possible and what, exactly I have to do.
The wi-fi cameras are all in the 192.168.1. *** range, as are the connected IP cameras although their assigned IP4's follow the NVR 192.168.1.12:65001-16 format. The internal IP4 addresses being in the 192.168.254.*** range. The RTSP (554) in the NVR is 'activated'. The ports of the IP cameras and the wi-fi cameras are set at 8000. I've been fiddling around with iVMS-4200 but I don't find it intuitive.
Contrary to my forum name I'm generally quite able to read, understand and comply - but I think I've lost the plot....
