A Typical query:
Looking for some assistance with designing and selecting hardware for an IP camera surveillance system for a domestic property. Never installed one before. Approx 3 cameras, outdoor covering front, back and front door, field of vision 50 to 90 deg night vision up to 20/30 meter, budget approx £500 to £800, want to connect with PoE however not sure how to connect to router in downstairs rear room from loft. Thinking about broadband extender to prevent having to run cable, but do not want to use a wireless system. Any advice and suggested hardware would be of assistance.
A suggested solution:
You can use a Homeplug solution to utilise the mains wiring in your home to extend the network from your router into the loft.
Connect an 8-port POE switch to the Homeplug in the loft.
Run a single cat5e network cable from the switch POE ports to each camera.
We don't offer the Home plug gadgets - a typical one here
I would recommend HikVision mini domes or bullets (ideally 3MP):
3MP HikVision mini bullets
3MP HikVision mini domes
The next grade up of cameras if budgets permit:
3MP vari-focal bullet
3MP vari-focal dome
The Synology NAS boxes make for a very good recording solution.
(see justification here)
You can of course use HikVision's free PC (or Mac) software, if you have and are happy to leave a PC running 24/7.
Hope that helps
3MP vari-focal dome
Hope that helps
