We have a wide frontage of 17.5m, with a depth to road of 8.5m, frontage split into the following:
|-gates-|----garage----|-front_door-|----house_frontage----|
|--3m---|-----4.3m-----|----3.2m----|----------7m----------|
Initially I was thinking of two cameras, one looking from the LHS of garage towards the house frontage and another on the RHS front door area looking towards the side gates. Mounting will be slightly above head height (approx 2m to 2.5m max). However I'm wary of making the house look like it's covered in cameras, so I'm now considering just a single very wide angle in the centre/to the RHS of the garage, which is flat roofed and 3m in height.
Due to access and wiring I ideally wanted avoid installing on the house frontage (which is set back 1m from the rest of the building, but all joined) as there is no easy cable route. The other areas are easily accessible for wiring.
The second stage will be two further cameras down the side gate area (leading from to garden), to cover the back door.
Any thoughts on coverage/number of cameras for such an area? Probably veering towards HikVisions turrets or domes (unless there are better choices) and they will either run via a Synology or HikVision NVR to begin with... needs reliable night vision, more interested in the quality than super-high megapixels. Everything will be IP PoE.
Thank-you![Smile :) :)](/forum/styles/default/xenforo/smilies/smile.png)
Thank-you
