Camera is over main home entrance, an angle of about 45 degrees, a height of 2.60 meters, heading is South-SE, and camera's lens top is reaching a distance of 15 meters.
Sensitivity is 100, Threshold(s) is 0, Alarm Validity is Basic, Intrusion area covers all front yard until the limit-border of fence, covering only 10% of road width, target size is max.
Last 15 days I had noticed around 5 missing Smart Events during the morning dawn and specifically till 08:30 am
Smart events were missing from VCA records for both Intrusion and Line Crossing.
All events were recorded as Motion Detection but only when Dynamic Analysis for Motion was enabled
Yesterday 08:15 a courier entered my property not through my gate but by the side, walking through my neighbours yard. He was loitering inside my yard, half yard length, moving forth and back for about 10 seconds, he was not detected by smart detection and then left going out through my yard gate. At that point he was detected and event was recorded on VCA
Today I decided to experiment and tested for about 2 hours 07:00 am to 09:00 am
Problem appears only for Humans and this is very difficult to verify because you need a second person to help.
Everything else, butterflies, insects, worms, birds, cats, objects like a broom and even an arm or hand were detected and almost all the times(95%) reported alarm and recorded as VCA events, anywhere inside the region area.
The problem appears at "lower" part to middle of the camera lens, when moving from "near(under the camera) to far". If the human target trancerns the center of region(and the center of camera lens), then is detected and gives an alarm. All events, humans and non humans are detected and VCA recorded when they are moving at the upper(lens) farthest part of region. I reduced the size of region to half the front length(middle to lower part only) and noticed that the same thing happens for "far to near" movement(middle of my yard to main entrance).
The problem occurs less times, if human target moves from left to right or right to left(90% detected)
Replicated "near to far" and "far to near" movement for about 100 times and there was only 20 times of detection. Most of the detections occured when sun exposed from cloudy sky and a sun elevation angle more than 15 degrees.
From 07:30 to 08:30 the sun beams hit the camera but not the lens inside camera. The sun is not visible by the camera.
Solved
www.use-ip.co.uk
Solved
Hikvision color vu not sending event notifications at night?
Yes. This is the "problem". But as I told you before, it's not a big deal since it works fine if all work is done by Camera. Its just an indication if at at least you don't save something by NVR at this particular setting The help file associated with both my M series NVR and the G5 camera both...
![www.use-ip.co.uk](/forum/proxy.php?image=https%3A%2F%2Fforum.use-ip.co.uk%2Fforum%2Fdata%2Fassets%2Flogo%2Ffavicon.png&hash=7533e7dec04b0589b5022a396a6305c5&return_error=1)
