Hello and thanks for reading
Is it possible to format the SD cards with the NVR? The cameras are all plugged in directly with POE and all work perfectly with the app etc, but none of the cameras show up in the SADP tool, nor on the browser (apart from camera management). If I go to storage management it only shows the main hard drive that installed on the NVR, and none of the SD cards located on the on-board storage of the cameras.
When I type in the camera IP address on the browser, is basically doesn't load anything and then times out.
NVR IP address is 192.168.1.66
Camera IP address is 192.168.254.8
All cameras were set up using the Plug and play setting
Been stuck on this one for a while so would really appreciate some advice!
Thanks!
![Big Grin :D :D](/forum/styles/default/xenforo/smilies/biggrin.png)
Thanks!
