how to find/reset username on hikvision OEM
Russell Coight
doing a rewire on a house and this includes replacing the cctv,
pulled out the old cameras and trying to reset them, they all seem like OEM with zero branding and weird software,
however the Domes work with Dahua ip and had a hard reset.
My issue is with the bullets, ive been over every inch of the inside trying to find a hard reset, there is none. they talk ok with hikvisions SADP, and i was able to successfully reset the password using its date (which seems stuck on 3 years ago) and serial number to gain a security code. however it seems like someone changed the username (and this doesnt get reset),
so i cant access the camera via a browser which needs a correct username/password combo.
is there anyway to find out the username?? or to reset this device?
yes its oem and a throw away most likely, but ive spent a day on it, replacing the corroded terminal, working out what wires to place where in an rj45 and getting it up and running, and researching this issue, now its becoming almost a principle thing,
not to mention ive learnt an extreme amount of information in the process
software version:HC200C2_AF_V0_Y_EN_L V2.3.11 build 2018-03-06 1
I can't think of a fix other than a reset button (check under the microSD card slot cover if they have one).
