Hey, new to the forum, so go easy if this question has been asked before or is common.
I'm looking to update my CCTV at my work place and install a new setup at my home.. I have heard that Hikvision has allot of vulnerabilities and can be hacked? What is the score, are they safe to use in the home or not?
I have currently the..
HikVision
DS-7708NI-SP
Firmware version - V3.4.5 build 170518
One with the disk drive built into the front.
All the cameras on it are 1.3MP and 3MP, dome style. (the two 3mp cameras updated in 2016)
I would say the whole set up is easily 10years old. Nothing can be updated to new firmware as it has stop been supported. (fairly sure this was fair while ago too).
I must say, it has the same hard drives in for last 10 years, and all channels run at full frame and record constantly without any sort of movement stuff set up (I found in first few years setting up movement caused issues with recorder, since turning it off never had any issues).
Only issues with NVR is one of the PoE failed, well a channel, so I'm a channel down and the power blew up about 2 years ago.. but as it runs a atx gaming pc power pack I just bought it a new pc power pack and sat it on top and its been working mint since
The cameras have nearly all failed at one point or another.. stripping them down it was just the dielectric coming out of capacitors.. soldering in new ons the cameras worked fine again..
Point I'm trying to make, to have worked this long and had minor issues I'm very impressed and would have liked to stick with Hikvision... but depends if the security is crap now?
The saving grace to my cameras is they have never been connected to the internet, so good look hacking that
but not because I didn't want too.. I remember trying the whole DNS pointing thing and port forwarding for it to be flaky as hell, and when it did work for the brief moment, it would do 1mb per second then die so was not useable.. all my cameras don't do the sub mask channel compression thing.. forget what its called.
So what is the verdict, are they safe or do I need to look at something else, and if so what is the new go to camera systems etc? I think I paid around £1500 for the recorder and 2x 3tb hard drives back when I first got it, the cameras where around £150-200 each.
One thing that stopped me from upgrading years ago was that next door unit got the new colour vue hikvision cameras few years back, and you couldn't make out the number plates in motion like mine can, and his was like 4MP or something.. don't know why, but mine seems to freeze frame stuff better and at night doesn't do that ghosting thing that h.265 seems to do in the compression?
Anyways... whats the score? lol
HikVision
DS-7708NI-SP
![Big Grin :D :D](/forum/styles/default/xenforo/smilies/biggrin.png)
![Smile :) :)](/forum/styles/default/xenforo/smilies/smile.png)
