Hikvision NVR 4.0 playback is not showing smart events?
TTraj
Hi everyone, I recently setup a DS-7608NI-I2 / 8P NVR and two DS-2CD2387G2-LU cameras. I have enabled motion and intrusion detection for both camera which works well. However, one of the cameras isn’t showing the smart events in the playback interface when I select the “smart” filter (it's a constant blue line). Furthermore, the same camera will not play any footage when I select the “smart” filter. If I use custom search and custom view this works fine. I can also see the smart events in the alarm notification. Any help will be appreciated, thank you.
Hi @TTraj
What firmware versions are the NVR and cameras currently running?
Can you post photos of what you are seeing when trying to view the Smart Playback?
Hi Dan,
Thank you for the response. I have fixed the problem by restoring the NVR and cameras to default-started from scratch.
FYI-at the time of the problem, I was running the latest firmware on the NVR and cameras.
NVR: V4.22.000 build 210615
Cameras: V5.7.2 build 220223
Regards,
TTraj
