Hikvision G5 DS-2CD2146G2-ISU [boot failed bootInfo = 26] error
z0re
I have a hikvision DS-2CD2146G2-ISU camera which has developed a fault. It partially works in that when turned on I am able to access the camera via http web browser but its laggy and crashes a lot. SADP tool recognises the camera. I thought it may be a firmware issue so i tried to update the firmware via the web browser but it failed (did not even send file). I then tried via tftp server but nothing happened, it acknowledges the camera, but no file is sent. I then connected to the camera via serial cable and could see an error repeating in the log which was as below
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 10 min and 17 sec )
I was able to perform firmware update on the camera but the above error has still persisted. Any ideas on how to fix this?
Full boot up code is attached below. I can see a few errors such as
1 - Run tee-supplicant ... device open: No such file or directory
2- ./loadNT9852x.sh: line 220: mdev: not found
3 - Jan 1 12:52:17 bsp.err kernel: [ 12.438545] Error: Driver 'nvt_pwm' is already registered, aborting...
4 -
debug_demo_mdk_create!
mount: mounting none on /proc/bus/usb failed: No such device
mount: mounting debugfs on /proc/bus/ failed: Device or resource busy
chmod: /bin/dsp_test: No such file or directory
Code:
dma1 zq_trim[e], ldo_trim[c]
DDR3_2133ver 2.00
ini_ver: 0x60210205
CPU1000 DONE
>dma1 ssc 1
dma ok
2 DR
dma2 zq_trim[e], ldo_trim[c]
dma1 ssc 1
dma2 ok
UNZOK!
Loader Start ...
LD_VER 03.01.07
528_DRAM1_1066_4096Mb_DRAM2_1066_4096Mb 04/10/2021 10:48:59
NAND,BS= 0x00000002
gpio ID2   0x00000000
gpio ID3   0x00000000
SPI NAND MID=000000EF DEV=000000AA
ld.LdCtrl2 0x00000000
LdCtrl2 0x00000000
teeos_addr 0x02000000
uboot_addr 0x0E000000
uboot_size 0x02000000
smp(tee2)
core2_jump_program 0xF07C0500
code2JumpCodelen 0x00000010
core2_entry2_addr 0x01FC0000
core2_entry_checksum 0x0000C40F
core2_entry_program 0xF07C0510
code2EntryCodelen 0x000001BC
0xF07F8000= 0x02000180
core2_reset
2ajcor1awaitump 0x02000180
abceRS2WK2
U-Boot 2019.04-svn1177869 (Apr 10 2021 - 10:49:09 +0800), Build: jenkins-Frontend.BSP.CCI.devCloud-3254
CPU:   999 MHz
DRAM:  256 MiB
l2cache:0
l2cache:1
bootmode = 0 addr=00007e00!
NAND:  id =  0xef 0xaa 0x21 0x00
nvt spinand 4-bit mode @ 12000000 Hz
128 MiB
MMC:   0
 misc_init_r: boot time: 1361907(us)
 misc_init_r: boot time: 1365909(us)
Net:   INTER MII
[Uboot] In release mode!
Hit Ctrl+u to stop autoboot:  0
|NUL ethaddr| error: auto upgrade.(error!!)
TFTP server auto connect disabled
Unknown command 'crc' - try 'help'
booting from sys part...
Load kernel to 0xc700000 ...
<sbal_wb_aes_update>...decrypt
<sbal_seboot>body_total_len=7724352
<sbal_seboot>verify success ##successful to load enc_uImage##
gzip_image_size  75dd28  image_size   f51d7c
nvt_ker_img_ungzip_linux: gz_uncompress linux
nvt_ker_img_ungzip_linux: generating uImage header for linux
CHIP_1.
Succeed!
## Booting kernel from Legacy Image at 0c720000 ...
   Image Name:
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    16063868 Bytes = 15.3 MiB
   Load Address: 00008000
   Entry Point:  00008000
## Flattened Device Tree blob at 0c700000
   Booting using the fdt blob at 0xc700000
   Loading Kernel Image
   Loading Device Tree to 087dd000, end 087fffff ... OK
Starting kernel ...
l2cache:0
Disable MMU
Clear MMU
Uboot L2 cache aux val: 0x72420000
Uboot L2 cache prefetch ctrl val: 0x70000000
Uboot L2 cache ctrl val: 0x00000000
Done
SW2
starting pid 159, tty '': '/etc/init.d/rcS'
Starting udev:      [ OK ]
create static device nodes under /dev dir
>>>run pre_app_hook
done
waiting for /dev/ubi1_0.
waiting for /dev/ubi3_0.
>>>run post_app_hook
process/
process/davinci_bak
Jan  1 12:52:11 bsp.warn kernel: [    6.778172] phydev exist: resume phy
Jan  1 12:52:11 bsp.warn kernel: [    6.778212] nvt_resume: find node^M
Jan  1 12:52:11 bsp.warn kernel: [    6.778218] nvt_resume: led-inv found^M
Jan  1 12:52:11 bsp.warn kernel: [    6.778223] nvt_resume: led-inv = 1^M
Jan  1 12:52:11 bsp.warn kernel: [    6.778239] nvt_resume: pinmux 0x12^M
Jan  1 12:52:11 bsp.warn kernel: [    6.801730] DWC_ETH_QOS_yinit: apb_clk 120000000 Hz^M
Jan  1 12:52:11 bsp.alert kernel: [    6.802751] Queue0 Tx fifo size 4096, Rx fifo size 4096
Jan  1 12:52:11 bsp.alert kernel: [    6.802768] Disabled JUMBO pkt
Jan  1 12:52:11 bsp.alert kernel: [    6.802786] Enabled Rx watchdog timer
Jan  1 12:52:11 bsp.alert kernel: [    6.802795] Enabled TSO
Jan  1 12:52:11 bsp.alert kernel: [    6.802799] Disabled Rx Split header mode
Jan  1 12:52:11 bsp.warn kernel: [    6.802825] phydev exist: start phy
Jan  1 12:52:11 bsp.info kernel: [    6.813166] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
process/database_process
process/daemon_fsp_app
process/net_process.lzma
process/hostapd.lzma
applib/
applib/libsqlite3.so.lzma
applib/libfsp_base.so.lzma
applib/libwebsockets_server.so.lzma
applib/libiconv_utf8Gbk.so.lzma
applib/libcrypto.so.lzma
applib/libssl.so.lzma
applib/libipc_unix.so
applib/libosip2.so
applib/libosipparser2.so
applib/libhikosip.so
applib/libserial_cmpt.so
applib/libcjson.so
applib/libprocess.so
applib/libremote_dbg.so
applib/libsave_alarminfo.so
applib/libcamflash_ipc.so
applib/libsyslog.so
applib/libhiksyslog.so
applib/libispfrontc.so
applib/libzoomcam_ipc.so
applib/libdadsp.so
hikmdk
hikdsp
Jan  1 12:52:14 bsp.warn kernel: [    8.897564] DWC_ETH_QOS_adjust_link: start tx/rx^M
Jan  1 12:52:14 bsp.info kernel: [    8.897584] DWC_ETH_QOS f02b0000.eth eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Jan  1 12:52:14 bsp.info kernel: [    8.897625] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
g5_isp_config.tgz
libg5_isp_ipc.so
ptzCfg.bin
ASC32
ASC16
GBK
serialCom
cellular_service
diald
chat
pppoed
pppoe
pppd
t1
da_info
execSystemCmd
sound.tar.gz
hikdrv/8189fs.ko
hikdrv/8192fs.ko
hikdrv/alarm.ko
hikdrv/an41908.ko
hikdrv/base.ko
hikdrv/bcm4359/
hikdrv/bcm4359/nvram_ap6398s.txt
hikdrv/bcm4359/nvram.txt
hikdrv/bcm4359/fw_bcm4359c0_ag_apsta.bin
hikdrv/bcm4359/fw_bcm4359c0_ag.bin
hikdrv/bcmdhd_sdio_bcm4359.ko
Jan  1 12:52:15 bsp.notice kernel: [    9.898026] random: crng init done
hikdrv/cdc_ether.ko
hikdrv/cdc_ncm.ko
hikdrv/cfg80211.ko
hikdrv/detect_sensor.ko
hikdrv/digital_display.ko
hikdrv/dome_timer.ko
hikdrv/dram_split.ko
hikdrv/ehci-hcd.ko
hikdrv/epatch.ko
hikdrv/esensor.ko
hikdrv/fotg200-udc.ko
hikdrv/fotg210-udc.ko
hikdrv/g_ether.ko
hikdrv/g_ncm.ko
hikdrv/hikcore.ko
hikdrv/hikio.ko
hikdrv/klog.ko
hikdrv/libcomposite.ko
hikdrv/localvideo.ko
hikdrv/m25p80.ko
hikdrv/motor.ko
hikdrv/option.ko
hikdrv/pt_stm8.ko
hikdrv/switch.ko
hikdrv/u_ether.ko
hikdrv/uart232.ko
hikdrv/udc-core.ko
hikdrv/usb_f_ecm.ko
hikdrv/usb_f_ecm_subset.ko
hikdrv/usb_f_ncm.ko
hikdrv/usb_f_rndis.ko
hikdrv/usb_wwan.ko
hikdrv/usbnet.ko
hikdrv/usbserial.ko
hikdrv/vd_notify.ko
hikdrv/wifi_rf.tgz
hikdrv/wps.ko
nvtdrv/sample_nvt_ext.ko
./af/
./af/nvt_af.ko
./comm/
./comm/kdrv_comm.ko
./comm/nvtmem/
./comm/nvtmem/nvtmem.ko
./disp_if8b_lcd1_tp2803/
./disp_if8b_lcd1_tp2803/disp_if8b_lcd1_tp2803.ko
./display_panel/
./display_panel/nvt_dispdev_panel.ko
./iq/
./iq/nvt_iq.ko
./isp/
./isp/nvt_isp.ko
./kdrv_ai/
./kdrv_ai/kdrv_ai.ko
./kdrv_audioio/
./kdrv_audioio/audlib_hik_aec/
./kdrv_audioio/audlib_hik_aec/hik_audio_aec.ko
./kdrv_audioio/audlib_src/
./kdrv_audioio/audlib_src/nvt_audlib_src.ko
./kdrv_audioio/audlib_aec/
./kdrv_audioio/audlib_aec/nvt_audlib_aec.ko
./kdrv_audioio/audio_common/
./kdrv_audioio/audio_common/nvt_audio.ko
./kdrv_audioio/kdrv_audio/
./kdrv_audioio/kdrv_audio/nvt_kdrv_audio.ko
./kdrv_gfx2d/
./kdrv_gfx2d/kdrv_affine/
./kdrv_gfx2d/kdrv_affine/affine_neon/
./kdrv_gfx2d/kdrv_affine/affine_neon/kdrv_afn_neon.ko
./kdrv_gfx2d/kdrv_affine/kdrv_afn.ko
./kdrv_gfx2d/kdrv_gfx2d.ko
./kdrv_ive/
./kdrv_ive/kdrv_ive.ko
./kdrv_videocapture/
./kdrv_videocapture/kdrv_videocapture.ko
./kdrv_videocodec/
./kdrv_videocodec/kdrv_h26x.ko
./kdrv_videoout/
./kdrv_videoout/display_obj/
./kdrv_videoout/display_obj/kdrv_videoout.ko
./kdrv_videoout/ide/
./kdrv_videoout/ide/nvt_ide.ko
./kdrv_videoout/fbdev/
./kdrv_videoout/fbdev/nvt_fb.ko
./kdrv_videoprocess/
./kdrv_videoprocess/kdrv_vpe/
./kdrv_videoprocess/kdrv_vpe/kdrv_vpe.ko
./kdrv_videoprocess/kdrv_videoprocess.ko
./kflow_audiocapture/
./kflow_audiocapture/unit/
./kflow_audiocapture/unit/kflow_audiocap.ko
./kflow_audioout/
./kflow_audioout/unit/
./kflow_audioout/unit/kflow_audioout.ko
./kflow_common/
./kflow_common/kflow_common.ko
./kflow_gfx/
./kflow_gfx/nvt_gfx.ko
./kflow_gfx/videosprite/
./kflow_gfx/videosprite/nvt_videosprite.ko
./kflow_videocapture/
./kflow_videocapture/kflow_videocapture.ko
./kflow_videodec/
./kflow_videodec/unit/
./kflow_videodec/unit/kflow_videodec.ko
./kflow_videoenc/
./kflow_videoenc/unit/
./kflow_videoenc/unit/kflow_videoenc.ko
./kflow_videoout/
./kflow_videoout/unit/
./kflow_videoout/unit/kflow_videoout.ko
./kflow_videoprocess/
./kflow_videoprocess/kflow_videoprocess.ko
./loadNT9852x.sh
./net_flow_sample/
./net_flow_sample/netflowsample.ko
./nvt_vencrc/
./nvt_vencrc/nvt_vencrc.ko
./vpe/
./vpe/nvt_vpe.ko
insmod pre_insmod
Jan  1 12:52:17 bsp.info kernel: [   12.425340] NVTMEM: 0.0.2
Jan  1 12:52:17 bsp.warn kernel: [   12.451840] log.ko v1.4: Jul 23 2021 18:01:04 (mmap 0x91240000 size 0x21800)
Jan  1 12:52:17 bsp.warn kernel: [   12.451861]
Jan  1 12:52:17 bsp.warn kernel: [   12.451861] LOG base 0x968c1c00(ddr0) size 1K (start pointer 0x7f075354)
Jan  1 12:52:17 bsp.warn kernel: [   12.451868] PAGE_OFFSET(0x80000000) VMALLOC START(0x97800000) HZ(100)
Jan  1 12:52:17 bsp.debug kernel: [   12.452340] nvt_sif_init:
Jan  1 12:52:17 bsp.debug kernel: [   12.452581] nvt_sif_probe:f0240000.sif
Jan  1 12:52:17 bsp.debug kernel: [   12.452596] nvt_sif_probe:0. resource:0xf0240000 size:0x200
Jan  1 12:52:17 bsp.debug kernel: [   12.452639] nvt_sif_probe:IRQ 0. ID51
Jan  1 12:52:17 bsp.debug kernel: [   12.452814] nvt_sif_probe:DevID Major:253 minor:10
Jan  1 12:52:17 bsp.debug kernel: [   12.453147] nvt_sif_drv_init:
Jan  1 12:52:17 bsp.warn kernel: [   12.464661]
Jan  1 12:52:17 bsp.warn kernel: [   12.491506] ERR:nvtmpp_parse_mmz_dt_p() dynamic_map not support 512MB/1GB^M
Jan  1 12:52:17 bsp.warn kernel: [   12.492868] nvtmpp_init_mmz: ddr1 pa = 0x17200000 va = 0x98980000 , size = 0x8e00000
Jan  1 12:52:17 bsp.warn kernel: [   12.501550] nvtmpp_init_mmz: ddr2 pa = 0x40000000 va = 0xa1800000 , size = 0x20000000
Jan  1 12:52:17 bsp.info kernel: [   12.526742] affine_neon_module_initial: successfully
Jan  1 12:52:17 bsp.warn kernel: [   12.535006]
Jan  1 12:52:17 bsp.warn kernel: [   12.536320] AFFINE addr 0xfdca0000^M
Jan  1 12:52:17 bsp.warn kernel: [   12.536425] nvt_affine_drv_init: done
Jan  1 12:52:17 bsp.warn kernel: [   12.561688]
Jan  1 12:52:17 bsp.warn kernel: [   12.563955] nvt_csi_probe:not fast boot
Jan  1 12:52:17 bsp.warn kernel: [   12.601653] f0c20000.dce^M
Jan  1 12:52:17 bsp.warn kernel: [   12.602831]
Jan  1 12:52:17 bsp.warn kernel: [   12.603064] IRQ 0. ID37
Jan  1 12:52:17 bsp.warn kernel: [   12.603256] DevID Major:253 minor:32
Jan  1 12:52:17 bsp.warn kernel: [   12.700374] WRN:nvt_afalg_init() motor drv is null!^M
Jan  1 12:52:17 bsp.warn kernel: [   12.700650] WRN:nvt_afalg_init() motor drv is null!^M
insmod post_insmod
./libDFR_Attribute_shared.so
./libDFR_Landmark_shared.so
./libhdal.so
./libprebuilt_ai.so
./libvendor_ai.so
./libvendor_ai_pub.so
./libvendor_media.so
dsp_G5.json
mv: can't rename '/home/dsp_extres/dsp_info': No such file or directory
cp: can't stat '/bin/dsp_info': No such file or directory
/bin
########## hikmdk  build at 15:52:41--Sep  9 2021 ############
mdk_build_time:2021-09-09 15:52:41
mdk_svn_url:https://192.0.0.241/DSP/Frontend/Novatek/NT98525/G5/branches/baseline/IPC/PJ01TD20210803261_v5.7.1_ipc_base/mdk
mdk_svn_version:
Insmod ko start...
insmod: can't insert '/home/plat_module/hikdrv/base.ko': File exists
insmod: can't insert '/home/plat_module/hikdrv/hikcore.ko': File exists
insmod: can't insert '/home/plat_module/hikdrv/hikio.ko': File exists
Press Ctrl-C to stop ...
Jan  1 12:52:18 bsp.info kernel: [   12.789444] nvt_audlib_aec driver for hik aec!
Jan  1 12:52:18 bsp.warn kernel: [   12.869672] nvt_dispdev_module_init:
Jan  1 12:52:18 bsp.info kernel: [   12.881001] Hello, panel: TP2803, is_ntsc 1
Jan  1 12:52:18 bsp.err hal_bsp[833]: [HAL_BSP][833][bsp_check_hikio_fd]:Please hal_hikio_init() first.
Jan  1 12:52:18 bsp.warn kernel: [   13.568208] sample ext
Jan  1 12:52:18 bsp.info kernel: [   13.576858] func:motor_module_init, successful to initialize motor!
Jan  1 12:52:18 bsp.warn kernel: [   13.584966] [LOCALVIDEO][localvideo_init]:register miscdev @ "/dev/localvideo" success!
Jan  1 12:52:18 bsp.info kernel: [   13.593295] nvt_gpio f0070000.gpio: HWIRQ: 40 IRQ: 296 ### Both Edge ###
Jan  1 12:52:18 bsp.info kernel: [   13.599847] nvt_gpio f0070000.gpio: HWIRQ: 20 IRQ: 276 ### Both Edge ###
Jan  1 12:52:18 bsp.info kernel: [   13.599943] nvt_gpio f0070000.gpio: HWIRQ: 21 IRQ: 277 ### Both Edge ###
Jan  1 12:52:18 bsp.info kernel: [   13.600007] nvt_gpio f0070000.gpio: HWIRQ: 31 IRQ: 287 ### Both Edge ###
Jan  1 12:52:18 bsp.info kernel: [   13.609429] [uart232]:default_setup: number = 0
Jan  1 12:52:18 bsp.info kernel: [   13.609514] [uart232]:register uart2 port [2] success
Jan  1 12:52:18 bsp.info kernel: [   13.610019] [uart232]:default_setup: number = 1
Jan  1 12:52:18 bsp.info kernel: [   13.610109] [uart232]:register uart4 port [4] success
Jan  1 12:52:18 bsp.info kernel: [   13.610562] [uart232]:default_setup: number = 2
Jan  1 12:52:18 bsp.info kernel: [   13.610652] [uart232]:register uart3 port [5] success
Jan  1 12:52:18 bsp.info kernel: [   13.610664] [uart232]:Successfully insmod uart232 module!
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][260]:###### unpack source[0] bPackVerFlg=0x00,bPackDevFlg=1010010011111110021,iFirmMapFlg=0x00000001,iFirmKeyFlg=0x00000000
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][262]:###### unpack source[0] iFirmOffset=0x0000006c,iFileLength=0x006716c5,iCheckSumU8=0x3355cd69
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][290]:###pack[0] iFirmFlg=0x00650100,iPlatform=101,iDevMajor=111,iDevMinor=111,iLanguage=2
Jan  1 12:52:19 bsp.err hal_bsp[899]: [HAL_BSP][899][bsp_check_hikio_fd]:Please hal_hikio_init() first.
Jan  1 12:52:19 bsp.warn kernel: [   14.646534] read headbuf = 224
Jan  1 12:52:19 bsp.warn kernel: [   14.646724] <sbal_wb_aes_update>...decrypt
Jan  1 12:52:19 bsp.warn kernel: [   14.648275] <sbal_wb_aes_update>...decrypt
Jan  1 12:52:19 bsp.warn kernel: [   14.648931] <sbal_seboot>
Jan  1 12:52:19 bsp.warn kernel: [   14.648938] body_total_len=243936
Jan  1 12:52:19 bsp.warn kernel: [   14.733740] <sbal_seboot>
Jan  1 12:52:19 bsp.warn kernel: [   14.733743] verify success
Jan  1 12:52:19 bsp.info kernel: [   14.734512] ##successful to hik_decode_daemon_toplained :/home/daemon##
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][400]:###file[0] szFileName=davinci.lzma,iFirmOffset=0x00000500,iFileLength=0x006711c5,iCheckSumU8=0xc18215b8
IEfile uncompressed.
Enter DB_main-------------------
DB_SHARE_MEMORY_ID 4442534d, sizeof(DEVICECONFIG) 3352232
shared memory address is: 0x76846000, sizeof(DEVICECONFIG) = 3352232
netprocess Infomation FSP_network_multi:
version: 1.9.0.765278 [21:14:27-Aug  6 2020]
Path: /Camera/Platform/Branches/branches_FSP_network_protocol/BASE/FSP_network_multi
Last Changed Rev: 931717
Last Changed Date: 2020-08-05 16:52:22 +0800 (Wed, 05 Aug 2020)
wait davinci set default...
[01-01 12:52:21][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:21][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:21][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:21][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
starting pid 911, tty '': '-/bin/psh'
BusyBox v2.0.1-1460430 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# [01-01 12:52:22][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:22][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:22][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:22][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[DAEMON][DBG_INFO][src/daemon.c][firm_file_output][390]:firm unpack file : /home/process/davinci.lzma succ.
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][265]:system cmd [lzma -df /home/process/davinci.lzma]
[01-01 12:52:23][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:23][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:23][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:23][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 12:52:24][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:24][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:24][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:24][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 12:52:25][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:25][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:25][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:25][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][282]:system [lzma -df /home/process/davinci.lzma] succ.)
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][265]:system cmd [/home/process/davinci &]
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][282]:system [/home/process/davinci &] succ.)
[PACK][DBG_HINT][src/firm_unpack_lib.c][firm_pack_decode][339]:###pack num=1,decode succ=1,permit denied=0
[01-01 12:52:26][pid:0][OTHER][INFO]boot_debug--21.401: ==main=
[01-01 12:52:26][pid:0][OTHER][INFO]boot_debug--21.403: user_sysinit in
[01-01 12:52:26][pid:0][SYSINIT][ERROR]
▒▒▒ܰ汾
▒豸▒ͺ▒: 0x24043 ,▒▒▒▒▒ͺ▒:DS-2CD2186G2-ISU
[01-01 12:52:26][pid:0][SYSINIT][ERROR]bootParms.icrSupport                     = 130
[01-01 12:52:26][pid:0][SYSINI^Qdavinci receive cmd_query_davinci_param.
[01-01 12:53:17][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
S: cmd_query_davinci_param
config_davinci_param
[01-01 12:53:17][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:17][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:18][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:18][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:18][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:19][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:19][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:19][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:20][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:20][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:20][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:21][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:21][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:21][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 0 min and 50 sec )
[DSP][ERR]<1000946>[DSP]<main><5432>:DSP_SMART_INIT fail !! smart_bootInfo = 0 !!!
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 10
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[audioVolume]
[01-01 12:53:22][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:53:22][pid:0][DSP][ERROR]mdk_av_get_audio_volume error!
[01-01 12:53:22][pid:0][UNI_IF][ERROR]ioctl(iopFd, HIKIO_SET_AUDIO_INPUT_MODE) error!
Jan  1 12:53:22 bsp.err kernel: [   77.725956] nvt_i2c f03a0000.i2c3: i2c_nvtim_xfer_msg(675) NACK!
Jan  1 12:53:22 bsp.warn kernel: [   77.725976] [LOCALVIDEO][tp2803fe_check_exist]:i2c_reg_read_byte TP2803_REG_ID_H(0xFE) error!
Jan  1 12:53:22 bsp.warn kernel: [   77.725982] [LOCALVIDEO][cvbs_chip_check]:cvbs chip TP2803_FE is not exist!
Jan  1 12:53:22 bsp.warn kernel: [   77.725987] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs_chip_check failed! ret = -1
[01-01 12:53:23][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:23][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:23][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:23][pid:0][HW_IF][ERROR]get_hal_mcu_info_task start.
[01-01 12:53:23][pid:0][UNI_IF][ERROR]not support light!!!
[PSWD][0095]:public_base64_len 188  len 140
[PSWD][0490]:public_base64_len 188  len 140
[PSWD][0524]:init_default_param_lib rsa_version[6]
[QR_CTRL]malloc_setting_size_buffer =0x0x1b1b308
[QR_CTRL]malloc_setting_size_buffer =0x0x1b12838
[QR_CTRL]malloc_setting_size_buffer =0x0x1b24c80
[QR_CTRL]malloc_setting_size_buffer =0x0x1b0d530
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_isp_config.json in dir[/dav/qr_isp_config.json]!
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_jx_config.json in dir[/dav/qr_jx_config.json]!
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_app_config.json in dir[/dav/qr_app_config.json] !
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_isp_source.json in dir[/dav/qr_isp_source.json] !
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_jx_source.json in dir[/dav/qr_jx_source.json] !
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_app_source.json in dir[/dav/qr_app_source.json] !
[01-01 12:53:23][pid:0][SENSOR][INFO][qr_malloc_json_buffer][QR_CTRL]malloc_setting_size_buffer SUCCESS !
[assemble_qr_config_json]--qr_config_json is {
[assemble_qr_config_json]--qr_transmit_json is {
        "data": []
[assemble_qr_transmit_json]-final-qr_transmit_json is {
        "data": []
front_task_dep_func_callback_init OK!
front_task_enable_init OK!
-------------------------------------------------send_heart_beat_timer------------------------------------------
[01-01 12:53:23][pid:0][SENSOR][INFO]RULE ENGINE: the icr task initialize successfully!
hwif_malloc_intel_buffer buffer_num=2
hwif_malloc_intel_buffer buffer[0]=0x0x70af7008
hwif_malloc_intel_buffer buffer[1]=0x0x704fe008
p_img_slot->data[0]=0x0x70af7008
p_img_slot->data[1]=0x0x704fe008
[01-01 12:53:23][pid:0][OTHER][ERROR]del_gateway ioctl error and errno=3
[01-01 12:53:23][pid:0][MOBILE][ERROR]comm_param is null.
Jan  1 12:53:23 bsp.err kernel: [   78.126377] nvt_i2c f03a0000.i2c3: i2c_nvtim_xfer_msg(675) NACK!
Jan  1 12:53:23 bsp.warn kernel: [   78.126397] [LOCALVIDEO][tp2803fc_check_exist]:i2c_reg_read_byte TP2803_REG_ID_H(0xFE) error!
Jan  1 12:53:23 bsp.warn kernel: [   78.126411] [LOCALVIDEO][cvbs_chip_check]:cvbs chip TP2803_FC is not exist!
Jan  1 12:53:23 bsp.warn kernel: [   78.126416] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs_chip_check failed! ret = -1
Jan  1 12:53:23 bsp.err hal_bsp[916]: [HAL_BSP][916][localvideo_hwinfo_init]:localvideo init failure, ret = -1.
Jan  1 12:53:23 bsp.err hal_bsp[916]: [HAL_BSP][916][hal_localvideo_set]:Now not support the HAL_LOCALVIDEO_CMD_GETMODE!.
Jan  1 12:53:23 bsp.err kernel: [   78.527183] nvt_i2c f03a0000.i2c3: i2c_nvtim_xfer_msg(675) NACK!
Jan  1 12:53:23 bsp.warn kernel: [   78.527201] [LOCALVIDEO][adv7393_check_exist]:i2c_reg_read_byte ADV7393_REG_ID_1(0x8C) error!
Jan  1 12:53:23 bsp.warn kernel: [   78.527206] [LOCALVIDEO][cvbs_chip_check]:cvbs chip ADV7393 is not exist!
Jan  1 12:53:23 bsp.warn kernel: [   78.527210] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs_chip_check failed! ret = -1
Jan  1 12:53:23 bsp.warn kernel: [   78.527216] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs chip match failed! chan:0 bus:18, addr:42
Jan  1 12:53:23 bsp.warn kernel: [   78.527220] [LOCALVIDEO][cvbs_chip_match]:cvbs chip match failed!
Jan  1 12:53:23 bsp.warn kernel: [   78.527224] [LOCALVIDEO][localvideo_cvbs_init]:cvbs_chip_match failed! ret = -1
Jan  1 12:53:23 bsp.warn kernel: [   78.527228] [LOCALVIDEO][localvideo_chip_init]:localvideo_cvbs_init failed! ret = -1
Jan  1 12:53:23 bsp.warn kernel: [   78.527232] [LOCALVIDEO][localvideo_ioctl]:HAL_LOCALVIDEO_PARAM_INIT localvideo_chip_init failed!
Jan  1 12:53:23 bsp.info kernel: [   78.533173] event 4 bind pid 980
Jan  1 12:53:23 bsp.alert kernel: [   78.534647] -->DWC_ETH_QOS_setsettings
Jan  1 12:53:23 bsp.alert kernel: [   78.548750] <--DWC_ETH_QOS_setsettings
Jan  1 12:53:23 bsp.warn kernel: [   78.815524] DWC_ETH_QOS_adjust_link: stop tx/rx^M
Jan  1 12:53:23 bsp.info kernel: [   78.815539] DWC_ETH_QOS f02b0000.eth eth0: Link is Down
[01-01 12:53:24][pid:0][HW_IF][ERROR]hal_mcu_info_get error ret=-38!!!!
[01-01 12:53:24][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:24][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_davinci_init_finish = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]net_boot_debug--79.531:
 ===Davinci  Init Finish...
S: cmd_get_enable_list
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR] db_get_sip_config
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR]param_idx =0
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR]p_sip_para->server_addr =
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR]param_idx =1
[01-01 12:53:25][pid:904][DOME][ERROR]invalid db_decrypt parameter, src len:0
[01-01 12:53:25][pid:904][UNI_IF][ERROR]kill dropbear pid:443 sucess
Jan  1 12:53:24 bsp.err hal_bsp[916]: [HAL_BSP][916][mcu_wait_char]:^M receive time_out^M
Jan  1 12:53:24 bsp.err hal_bsp[916]: [HAL_BSP][916][receive_ack_from_mcu]:receive none from mcu^M .
[01-01 12:53:25][pid:0][ALARM_EXP][INFO]start init eda pubsub
[01-01 12:53:25][pid:0][ALARM_EXP][INFO]start init uv loop filter module
[01-01 12:53:25][pid:0][FACE_SNAP][INFO]event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]lineCross event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]lineCross EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]intrusion event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]intrusion EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]fastMove event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]fastMove EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]loitering event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]loitering EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectLeave event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectLeave EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectRemove event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectRemove EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]regionEnter event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]regionEnter EventCapture register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]regionExit event register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]regionExit EventCapture register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]peopleGather event register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]peopleGather EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]Parking event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]Parking EventCapture register ok.
[01-01 12:53:25][pid:0][E^Q[DSP][LOG] hikdsp still alive        [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and  0 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 11
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[waterMarkEpt]
[01-01 12:53:38][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:53:38][pid:0][SYSINIT][ERROR]hwif_water_mark_ctrl failed, chan:1
[01-01 12:53:38][pid:0][DSP][ERROR]1 chan do not support people counting, just return.
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 10 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 12
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[OSDParam]
[01-01 12:53:48][pid:0][DSP][ERROR]send  fail ret= -9
[ISP_FRONTC][ispset_param_group_frontc] chan[0], cmd = 34, value = 1
[ISP_FRONTC]get_cur_app_wdr_mode,chan:0, wdr/hlc(0/1):1, wdr_en:0, wdr_level:50
[ISP_FRONTC]viType:56, cap_Mode:54, impl:1.
[ISP_FRONTC]util_trans_sensor_original_size_frontc 0#3840*2160@25fps viStandard = 2
[01-01 12:53:48][pid:0][ISP_FRONT][ERROR]json open failed(No such file or directory): use default params
[ISP_FRONTC]chan[0] dev_type = 0x24043
[ISP_FRONTC]capture_mode_type = 0 crop_x = 0 crop_y = 0 crop_target_w = 0 crop_target_h = 0
[ISP_FRONTC]NORMAL_CAPTURE_MODE
[ISP_FRONTC]match vi (success!!) isp_original_viw = 3840  isp_original_viH = 2160 frame_rate = 6400
[ISP_FRONTC]config_capture_mode_frontc cap dev type = 0x24043
[ISP_FRONTC]config_capture_mode_frontc cap isp_original_viW = 3840 isp_original_viH 2160
[ISP_FRONTC]config_capture_mode_frontc cap image_viW = 3840 image_viH 2160
[ISP_FRONTC]config_capture_mode_frontc cap hdr_mode = 0 frame_rate = 6400 capture_mode_type =0 viStandard = 2
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 20 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 13
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[captureMode]
[01-01 12:53:58][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:53:58][pid:0][SENSOR][ERROR]cmd [105] fail
[ISP_FRONTC]chan[0] config_capture_mode_frontc ret = -3
[ISP_FRONTC][ispset_param_group_frontc] chan[0], cmd = 34, ret = -3
[01-01 12:53:58][pid:0][SENSOR][ERROR]frontd_lib_param_set err
[01-01 12:53:58][pid:0][DSP][ERROR]config_capture_mode_setting failed
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 30 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 14
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[voStatus]
[01-01 12:54:08][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:54:08][pid:0][DSP][ERROR]*******chan = 0x1, streamclass = 0x1*******
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->bSmart264 = 0
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->streamType = 0x1001
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->resolution = 0x1040
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->quality = 0x11
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->bpsType = 0
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->bps = 12582912
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->fps = 25
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->IFrameInterval = 50
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.videoType = 2
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.audioType = 0
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.profile = 1
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.b_svc_mode = 0
[01-01 12:54:08][pid:0][CAPA][ERROR]get_current_res_index failed stream_idx = 1, resolution = 251934745.
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 40 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 15
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[audioParam]
[01-01 12:54:18][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:54:18][pid:0][DSP][ERROR]get AudioParams  fail ret= -3
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 50 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 16
[01-01 12:54:28][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:54:28][pid:0][DSP][ERROR]mdk_av_set_audio_enc_type    fail ret= -3
[01-01 12:54:28][pid:0][DSP][INFO]HOST_CMD_SET_ENCODER_PARAM streamClass = 1, enc_param.fps=65561, resolution=4160
# [DSP][LOG] hikdsp still alive [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and  0 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 17
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[streamEncodeParam]
[01-01 12:54:38][pid:0][DSP][ERROR]send  fail ret= -9
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and 10 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 18
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[forceIFrame]
[01-01 12:54:48][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:54:48][pid:0][DSP][ERROR]1 chan do not support people counting, just return.
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and 21 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 19
[01-01 12:54:58][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:54:58][pid:0][DSP][ERROR]mask region :[0]
[DSP][LOG] hikdsp still alive   [build:Sep  9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and 31 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 20
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[videoMask]
[01-01 12:55:08][pid:0][DSP][ERROR]send  fail ret= -9
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx:1 stream:1 support
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx:1 stream:2 support
streamRecord[1]: start...
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx is 1 stream_max_id is 2
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx is 1 stream_max_id is 2 cap_value is 16398
[01-01 12:55:08][pid:0][SYSINIT][ERROR]0000000000 chan 1 stream_idx 2 to 0x56.
[01-01 12:55:08][pid:0][DSP][ERROR]*******chan = 0x1, streamclass = 0x2*******
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->bSmart264 = 0
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->streamType = 0x1001
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->resolution = 0x1056
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->quality = 0x11
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->bpsType = 0
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->bps = 1048576
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->fps = 25
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->IFrameInterval = 50
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.videoType = 2
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.audioType = 0
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.profile = 1
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.b_svc_mode = 0
[01-01 12:55:08][pid:0][CAPA][ERROR]get_current_res_index failed stream_idx = 1, resolution = 251934745.
Hi @z0re
We've not seen this exact issue before, can you please confirm the firmware version your camera is currently running? Can you also confirm which browser you tried to update the firmware from?
Hi @z0re
Hi Dan
I tried updating the camera firmware through internet explorer which did not work. Currently the camera is running the latest firmware which is V5.7.2_211109 and this was achieved through serial port update command over TFTP server. But the error message still persists after the firmware update.
Ok, if the error is still persisting after the firmware update that sounds like a software/hardware fault with your unit as no one else has reported this issue. I would take this issue back to the seller you purchased from and try to arrange a warranty replacement.
