HIKVISION DS-KD8003-IME1 video intercom modular door station to gate motor help
j1000
Hello all,
I have purchased a Hikvision DS-KD8003-IME1 video intercom modular door station and I need to connect it to my sliding gate motor.
On the back of the door station there are NC1 and NO1 terminals. I believe these are to open and close the gate.
The gate motor is a Nice ROBUS RB600. There are several terminals on this motor. Open, close, sbS, stop, Bluebus etc.
Can anyone advise which wires I need to connect from the door station to the gate motor please?
Any help would be most appreciated. Thanks.
It's not wise to connect the controller directly to the motor.
Any problem or fault with the motor, cabling, or installation could damage the controller.
You should use an interposing relay.
The controller switches the relay, and is therefore only switching the tiny load / current draw of that relay's coil.
The relay's switch contacts switch the current to the gate motor load.
Search this forum for relay and you should find lots of mentions for similar applications.
