Hikvision Doorbell - Pulling the video stream into a Non Hikvision NVR?
bm_99
Hi all, I have a hikvision KV6113 - WPE1 C doorbell
I'm upgrading my DVR, which is also going to have some IP cams added, and want to pull the stream of the doorbell in.
Am I limited with which recorder I can use or can I bring the stream into any DVR which also has IP cams added?
Yes you can add this doorbell same as any other Hikvision ip camera.
What DVR make and model are you intending to use?
I believe they do not support ONVIF protocol.
So i totally doubt it'll work on 3rd party NVR/DVR
I didn't see RTSP capability on doorbells. The standard RTSP url does not work, neither are there RTSP auth settings available
From what Hik said, the doorbell does have RTSP just not ONVIF.
Don't really want to change the doorbell to be fair
