Hikvision camera failure - the most common cause
Having been an official Hikvision UK partner for a few years now, we've seen our fair share of Hikvision camera failures.
It's inevitable with any electronic device of course, but we've seen the same failure with Hikvision cameras time and time again - and it's almost always caused by a installation error from the end user rather than a fault with the camera itself.
The issue is water ingress into the camera's RJ45 POE connection, caused by improper weatherproofing during installation.
The vast majority of Hikvision's most popular cameras have a short pigtail lead, or cable whip, extending from the camera (typically about 12" - 15" long) to which you'd make any relevant connections. These often include a female 12V DC barrel plug, an audio and alarm I/O terminal, and most crucially a female RJ45 connection to provide the camera with a network connection or a source of POE power.
You can see this cable whip wrapped around a few Hikvision models below.
Typically, this leads to a camera with an intermittent network connection, and indeed one that might not even power or generate a network connection at all. The only way to resolve this is to completely replace the RJ45 connection as per our guide on the process or return it to your supplier to be repaired (often at a price).
This is due to water ingress corroding the pins of the RJ45 connector. You can double-check to see if it has happened to your own camera if you're experiencing issues.
Below is a photo I took of a severely corroded camera we had returned to us recently.
_________________________________
How do I prevent this from happening to me?
There are a number of best-practise steps you can take in order to prevent this happening to you, and most of them are low-cost and pain-free (for once!).
With most Hikvision cameras that have a cable whip, Hikvision provide a weatherproofing cable gland accessory in the box.
However, it does seal the RJ45 connection of the camera quickly and easily, and is absolutely perfect if you're after some basic weatherproofing.
Below is how it looks once it's installed over the network connection.
However, if you want to be extra-certain, you can also consider wrapping the connection in self-amalgamating tape, or electrician's tape as it's often called. You can pick this up from any local hardware wholesaler or online very cheaply (often under £5 for a large roll) and will help seal the connection against water ingress even further.
Below is an example of this being put into practise, admittedly a little hastily (and untidily!).
Perhaps the most reliable and popular method to weatherproof your camera's cable whip however is by using an applicable Hikvision junction box or wall-mount bracket.
Hikvision recommend using some weatherproof sealing putty in conjunction with a junction box or wall mount should complete weatherproofing be absolutely critical, although for many it's not required.
An added benefit of using either of these is that it brings the camera off the wall it'd otherwise be mounted directly on to, allowing greater flexibility when choosing viewing angles - for example, it may be required to use a wall-mount arm in order to view down along the same wall the camera is mounted against.
Of course, true best practise would be a mix of all of the above in order to fully weatherproof your camera, but for most, simply applying just one of the above will do wonders to extend the lifetime of your camera, depending on your climate.
I would strongly encourage you at least deploy one of the above methods, or any other method to weatherproof your camera - hopefully before you have to return it!
