M mumin Member Messages 6 Points 1 Dec 4, 2024 #1 When ever I try to use my 2 way audio camera I get this error code 031003 also I can't sound the alarm on the camera.
JB1970 Guru Trusted Member Messages 3,753 Points 113 Dec 4, 2024 #2 mumin said: When ever I try to use my 2 way audio camera I get this error code 031003 also I can't sound the alarm on the camera. Click to expand... More information needed: camera model number camera firmware version NVR model (if camera connected to NVR) NVR firmware version Android app or iOS app Hik-Connect version How is the camera or NVR linked to the Hik-Connect app
M mumin Member Messages 6 Points 1 Dec 4, 2024 Thread starter #3 (Analog Camera) DS-2CE16DOT-LPXTS I currently can't tell you the firmware version (DVR) IDS-7204HUHI-M1/X V4.75.101 build 240419 Android 6.6.500.1107
JB1970 Guru Trusted Member Messages 3,753 Points 113 Dec 4, 2024 #4 mumin said: (Analog Camera) DS-2CE16DOT-LPXTS I currently can't tell you the firmware version (DVR) IDS-7204HUHI-M1/X V4.75.101 build 240419 Android 6.6.500.1107 Click to expand... Looking at the specs, the camera is an AoC model (Audio over Coax). However I can't see anywhere in the specifications for the DVR that it's an AoC model. My guess is that the DVR doesn't support it and that's why you're getting an error code.
