I became so frustrated with the unreliability of the Hikvision cloud service (ezviz / hikconnect) I setup the VPN server on my home router. Since then I've had no problems viewing my cameras when I'm away from home. I also use the NVR to send email alerts.Hi, can we use Hikconnect without Hikvision cloud system? So we can link direct to our internal system? Maybe with some portwarding of a webservice?
I don't use those devices, as long as you are connected to your home VPN server it should work and operate as if you were at home. Can your video intercom send email alerts?yes, to view cameras, that should work indeed, by adding them manual
but what about cameras from a videointercom?
will it be able to capture a doorpress event.? will the phone ring? when i add the videointercom manually on port 8000 , i also dont see a button to unlock / open the door ... i see the button when i add it to hikconnect service
I would assume that yes, we are dependant upon Hikvision maintaining the service.what happens if hikvision stops with their systems? we cant use push anymore then?
I think the intercoms may be dependant on Hik Connect but I've never used them. Like I mentioned though it's simplex audio - no simultaneous talk and listen.is that ivms 4500 also used for intercoms? i dont have cameras![]()
