@Dan @Kyle I broke this into another thread as although the other users' issue is resolved it highlights an issue with other camera models.
I've tested several cameras with 'active deterrent' or 'live guard' connected without an NVR to Hik-Connect, and found it's not possible to arm/disarm the audio and light alarms and there is no one key disarm icon (bell) to enable/disable notifications.
It appears Hikvision are fully aware of the issue, as the firmware for the G5 platform - '5.7.3_220216SP (fix the light and audio alarm on HC)' resolves it. However there is no corresponding patch firmware for the G3 (non c) models so if you have any of the following:
- DS-2CD2xx6G2-ISU/SL (G3 platform)
- DS-2CD2xx7G2-LSU/SL (G3 platform)
The camera won't work as intended with Hik-Connect unless using an NVR.
