Hi All,
I have had the DS7616NI-I2/16P running flawlessly for over 8 years. Today i noticed that the fan noise was fluctuating along with a click that sounded like a hard drive parking. No HD errors were being reported. Thinking it might be a failing hard drive, i powered down with the intention of disconnecting one hard drive to find which one it was. However, now i have no power to the hard drives at all and a clicking noise is coming from the main pcb so i assume the unit has now failed. Any thoughts?
If I need a new NVR - which is the best to go with?
Although i only need 8CH, the reason i had the 16channel was because originally i had the 8ch but this was very underpowered and was constantly causing issues.
I'm also confused as to what is offered on the use-ip website - there seems to be the same device listed several times but at different pricing.
My other concern is regarding the existing cameras. I am not 100% sure i can remember what all the passwords were etc -so am i going to have issues with connecting the old camera's to the the new NVR? Same goes with setting up the hik-connect app......
Any advice would be greatly received!
Andy.
Andy.
