I'm wondering if anyone has had disk issues with the DS-7716NI-M4?
I installed one in late November (firmware 4.63.020) and installed four 6TB Toshiba S300 drives.
Jan 31st I arrived to do some additional work and found the recorder showing a 'HDD Error' and going into the storage configuration HDD3 and HDD4 were both missing with the logs showing that a week previous HDD3 had failed and exactly one hour later HDD4 also failed. The NVR was rebooted and the disks were 'found' and everything was up and running again.
Feb 7th I've had a call with a further HDD error for HDD4. Power on time for the disks is only 67 days. I've done a full database rebuild and the disks pass a short self test. I notice that although all 4 disks pass the short self test in SMART settings, HDD4 seems to freeze on 10% progress before eventually reporting 'succeeded'; the others all progress 10, 20, 30% etc before reporting succeeded. I'm not sure whether to be considering a bad batch of Toshiba disks or a dodgy NVR.
