Hi Newwby here
I have a DS-2CD2386G2-ISU/SL ip camera that had IPC_G3_EN_STD_5.5.131_200220 firmware installed with RTMP firmware added. I've just done an update but installed IPC_G5_EN_STD_5.7.13_230504 by mistake
Now I cannot install any G3 firmware or RMTP firmware. If I try to revert back I get the mismatch error.
My questions are
1 Is there any RTMP firmware for the G5 installed version as all the portal versions are too low?
2 Is there any way to switch back to G3 versions of the main firmware so I can load the correct version of RTMP firmware
Thank in advance?
Steve
My questions are
Thank in advance?
Steve
