CCTVRONNIE
I am planning (still...) my cctv system and am considering the turret cameras. As I will be coming through an external wall, I assume that I should invest in
something like the following:
Also, with the deep base, I notice there is a side connection where I assume a conduit could be connected; my question is, is the connection nut on the base (to connect the conduit) lockable, or could someone unscrew the nut and poke around with their finger, screwdriver inside the base?
DS-1280ZJ-DM21 deep base
to allow space for the cabling/connections, as I expect this would be easier than having the connections inside the house?Also, with the deep base, I notice there is a side connection where I assume a conduit could be connected; my question is, is the connection nut on the base (to connect the conduit) lockable, or could someone unscrew the nut and poke around with their finger, screwdriver inside the base?
