Does my system have room for another camera?
adamlavv
Hello,
Current system is a DS-7608NI-M2 / 8P with below;
DS-2CD2366G2-ISU/SL x 2
DS-2CD2386G2-ISU/SL x 4
DS-2CD2387G2H-LISU/SL x 1
Would my system have the capacity to support a DS-2CD2T87G2P-LSU/SL as I'm not sure if the dual lens aspect = two additional cameras.
Thank you
Hi @adamlavv
The 2T87G2P camera does have 2 sensors but these are combined to create one panoramic image that is added as one channel to the NVR, so it should be fine to add. Still, you might have to reduce some of the stream settings of your cameras because 6 x 8MP (using around 15-20Mbps each) and 2 x 6MP (using around 10-15Mbps each) cameras could exceed the 128Mbps incoming bandwidth limit of the NVR when all are on their max settings.
