Hi all, I'm planning on ordering some Hikvision DS-2CD2386G2 cameras and have been speaking to different companies about installing them, however I'm getting conflicting answers from them on different things, which I need to decide before I can order, but I'm not sure which one to trust.
1. I am mounting my cameras on the side walls of my property, do I need a deep base (eg. DS-1280ZJ-DM21)? Some say they can do it without a deep base, while others say I need it. I have seen photos online of cameras without deep bases, but not sure if they have as much cables as Hikvision cameras. Obviously, if possible, I would like to not buy an extra deep base, as it increase the size of the camera and also it has a side hole, which doesn't look great?
2. If I don't use a deep base, does it mean the drilled hole will need to be bigger to hide the cables? Which I would rather avoid, and just buy the deep base if that is the case. I'm just trying to understand why the extra bases are needed.
3. For one of the cameras, the cabling is required to go round the outside of my property, passing and hiding through some gravel, a company is selling me Steel Wire Armoured cables at an extra cost? Is this necessary? While another company is telling me "direct burial cables" is sufficient. They also tell me if I use SWA, I can't use the Hikvision Deep bases, as the hole is not big enough, it needs to be over 20mm. Is this true?
Please can someone help, thank you in advance.
