Can 10TB or larger hard drives be fitted into HikVision NVRs
koaly
Could you please clarify, whether HDD larger than 10Tb will be working in the Hikvision DS-7608NI-I2?
The datasheet says "up to 10 TB capacity each". I am wondering what will happen if I put single 14Tb drive?
Would the NVR recognize the drive? What drives this limitation of 10Tb?
Thanks!
A hard drive bigger than 10TB should work fine in a HikVision NVR.
The reason it states only up to 10TB is that HikVision hasn't fully tested their NVRs with anything bigger yet. In reality, there is little difference between the different sized HDDs so shouldn't cause there to be an issue.
