Camera freezing when moving?
JulioFr1ch
hey hello everyone, today I am attaching a video that shows my problem, I have a P1468-LE connected to a Hikvision NVR is it jumps frame rates you will see at 10:21:24 it freezes, note that the results are the same on my NAS Syngnology the frequencies also jump at times on the video, how to fix this? an idea ?
View video
thank you in advance for your help
Hi @JulioFr1ch
Where was the video extracted from? Directly from the camera, from the Hikvision NVR, or from the NAS?
Have you checked that the stream settings (e.g. resolution, frame rate, H.264/H.265 CODEC, etc...) are all set the same on the camera, NVR, and NAS?
Sometimes stream glitches like this can appear if the settings are not aligned.
