Camera above front door recommendations please
Redialnow
Current setup:
1 x Hikvision DS-7608NI-I2-8P
2X Hikvision DS-2CD2385FWD
I am soon to purchase another cpl turret cameras but I am also looking for recomendations for a camera for above my front door. The camera will be above the door and to the right. It will be out of the weather as will be in a porch. I reckon something with 2.8mm for close up? If possible would like to use it to communicate with anyone at door (both hear them and speak to them).
Paul
Have you considered a Hikvision doorbell?
Hikvision DS-KB6003-WIP WiFi Doorbell
No outdoor Hikvision camera has a built-in speaker for two-way comms.
Adding a speaker to a camera that does have two-way audio capability is a complete faff (as well as the speaker you will need to install an amplifier!).
If you can live without the speaker, and are happy just to listen, then this flat dome has a built-in microphone:
Hikvision DS-2CD2563G0-IS 6MP Mini Dome Network Camera
Hi Phil,
Thanks for info Phil. This response has been edited because just realised door bell is wifi. The problem I would of had with doorbell is the cat 6 cable would not of reached. Will certainly look at wifi doorbell.
Thank you for the information.
Thanks again Phil.
Best regards,
Paul.
