I have a DS-2CD2135FWD-I camera connected to a DS-7604NI-K1/4P(B) nvr. The camera is above the front door and I have been using Hik-Connect on an old iPad mounted on the wall to show a permanent live view. We can see who is coming to the front door.
(I believe) Recent updates to Hik-Connect have caused the old iPad to struggle. Live view disappears for no apparent reason from anywhere between two minutes and a couple of hours. It just drops back to the desktop and a double tap on the home button shows the app still running in the background. I think the old iPad hardware is now not up to the job.
I also run Home Assistant and have the camera set up as a 'generic camera'. The problem using that display is that its very laggy. Sometimes I can see myself arriving home!!
There are a number of other ways to get the camera into HA, but all seem to need an rtsp stream. I can't for the life of me get rtsp to work.
I think I have tried every combination of url possible but nothing works. I'm using VLC to test the streams but they all fail. I have tried on both my iMac and a Windows laptop with the same results. I look at vlc logs but they make no sense to me at all.
The most mentioned url seems to be rtsp://<nvrip>:<port>/Streaming/Channels/101 but that doesn't work.
Any suggestions of how to get rtsp working or a different solution to my problem greatly received. I want to avoid buting a new iPad if at all possible.
Sorry if it's a bit TL-DR.
