Hello,
I have a Hikvision DS-7732NXI-K4/16P NVR.
When I use the included POE ports and first setup the cameras over plug and play it seems to work with an internal IP, but I cannot reach the cameras from local network, and if I change the port to manual and add a camera with a fixed IP the NVR won't see the camera.
For example, when I set up the camera using plug and play the ip is 192.168.251.x but my local network is 192.168.2.x
My question is - how can I manage to make the camera work with a local IP and use the NVR ports?
Or, do I need to leave it as plug and play?
Thanks in advance for you help
