BillyGoat20
Hi all,
I'm considering a 2 Mini Dome camera Hikvision DS-2CD2546G2-IS system for front and back of the house, It's a small 1.5 floor house with large soffits to the front and rear which would be suitable for a smaller/more subtle camera style. it has a narrow footprint so the angle of coverage should be suitable with a 2.8mm focal length.
I've considered both colorvu and IR cameras, and being that its a residential with some street lighting I'm in two minds between the 2 options of recording at night. Initially I was put off dome camera because of the IR flare on the lens - however with the Gen2 version this appears to be less of an issue?
I'm wondering if Accusense IR models could be supplemented with an IR illuminator such as rayTEC VAR2-PoE-i2-1 located at an offset (up to 4m) and pointing away from lens to provide increased illumination for the camera at 5-6m without causing increased glare?
If this system was to work, and both cameras and IR Illuminators being POE, which NVR would be most suitable, a DS-7608NI-I2-8P I presume the IR Illuminator is permanently activated?
