I spoke to a supplier this morning regarding a back order on DS-7604NXI-K1/4P(D) NVRs. The single HDD models of these NVRs were supplied without the 40mm case fan. I've been told that due to a higher than expected number of failures, they are opening all units on arrival and retrofitting the fan, as Hikvision and Seagate think that excess heat may be the cause.
@Smoggie89 - I immediately remembered your post regarding premature HDD failure:
www.use-ip.co.uk
HDD Exception?
Hello everyone I think I already know the answer to this question lol but it's the first time so just after some advice from people who know. I woke up this morning and the NVR was beeping DS-7604NXI-K1/4P(D) and when logging into Hik-Connect it had the red warning with HDD Exception and all...
